im Axle Specialists
Old 14-08-2010   #1
1.2.... 60 75 85 differences in hardware?
Hi just got a cheap mk1 1.2 60s, and was wondering if anyone could tell the the differences in hardware between the 60 75 and 85 1.2? Is is just a case of ecu/key change or do i need to make other changes?
Im just looking for as much power as i can from stock items before i go any futher
thedadio is offline Reply With Quote Quote
Old 14-08-2010   #2
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
Re: 1.2.... 60 75 85 differences in hardware?
Quote Originally Posted by thedadio View Post
Hey, welcome to the forums
For modifying engine wise its not that good for a punto but lots of cinq's have engine mods so have a look in that section
"60,75,85" is how much they should put out a new when there all in good working order so these engines now adays you would look at a bit less
60- standard SPI nothing fancy just a really, 8 valves to this engine
75- re-worked cylinder head design with better flow and is MPI also the engine is slightly taller, 8 Valves to this engine
8- 1.2 completely different to the engine above as this had 16 valves, its MPI and has rather alot of kick up its backside
the 75 you can get away with splicing the injector into the original loom and retain the original keys
for the 85 its alot of hassle, easier if you have one to start off with or have one as a donor car as you will need engine mounts ECU keys lock ariel code-box and some others
hope this was some help
Ash
if its cheap its generally cheap for a reason
whitz is offline Reply With Quote Quote
Old 14-08-2010   #3
There is not much point in doing the engine without upgrading the brakes and suspension.
Insurance costs rocket when a car is souped up and forgetting to tell them = no insurance when you need it - yes they do check. Especially with younger drivers.
DaveMcT is offline Reply With Quote Quote
BattleField 2142 (Your Hardware) Trancendental Gaming 56 21-01-2007 04:40
Wii hardware essentials ? Koa Gaming 8 01-12-2006 12:56
Hardware question... Hellcat Leisure Lounge 21 08-06-2006 10:25
Found new hardware Fast Finger Computing 8 08-09-2005 23:16
(T) ECU hardware Number Scorg Stilo 11 02-02-2005 14:13
