I tried this and the spring do not simply get removed. In fact without putting the spring compressors they will not come off. The pretension on standard springs seem too high to allow just removal. In fact both front and rear springs on my Mk1 punto are pretty impossible to remove without spring compressor.Raise the rear of the car using a trolley jack and a block of wood under the rear beam. Put axle stands under the sills and lower the car onto them. Reposition the trolley jack under the trailing arm and raise slightly. This will take the pressure off the damper bottom bolt, which you can then remove. When you lower the trolley jack back down again, the spring will decompress and can be simply removed. Repeat on the other side, and use the reverse procedure to re-install. Saving final tightening until the weight of the car is on the ground.
passed MOT no problem so i guess they weren't that bad after all
I've recently had to spent £300 on two lots of welding - and its only a Y reg.
looks like this was the only thread detailing the job..,
anybody like to offer thoughts/experience of removing the rear dampers from a 51 plate punto..
just how well rusted in are the mounting bolts likely to be..??
I'm going to soak everything for days before the swap-around,
Charlie
Soak everything in plusgas, might be worth spraying some rust remover into the back of the subframe which the bolts pass through.
Much easier with a impact driver to hammer the bolts out, using a long breaker bar will wind them out but you risk sheering them.
