Hi, new to the forum and have just bought the wife a 2001 1.2 ELX punto
The speedo & rev counter needles do not light up in the dark does anyone know how to change the bulbs for theses?
If the cluster is like my mk2b, then it is not possible to simply 'change the bulb'. The lights are actually LED's soldered onto the cluster's mainboard. It's no problem replacing them, but you need the identical replacement type and a steady hand in soldering.
This thread is about changing the colour of your LED's but can also be applied to replacing the existing ones... https://www.fiatforum.com/punto-guides/101234-punto-mk2-blue-dash-lights.html
