shaun200765
Member
Clutch: to change or not to change? Mk2 8V
When I depress the clutch pedal with the engine stationary, the pedal gets to about half way down before making a big clicking sound from under the bonnet and a corresponding notchy feel from the pedal.
Its not much better when its running either although its not slipping at all and the gear changes are reasonable although I suspect its not disengaging properly and most likely causing the notchy 3rd gear I can feel each time
I'd put money on it being the release fingers being worn on the clutch diaphragm. I'm a little gutted really because I really look after the car and always give the clutch an easy time of it. But its not a new car and for all I know the previous owner may have sat there at junctions with their foot on the pedal or used it as a foot rest on journeys
So, dunno what to do now. Should I change it for a new one or bear with it until it gets worse?
The way I see it, its not going to be doing the gearbox any favours if its dragging between gears and if it fails completely then I will be in trouble if its a long way from home.
Not sure here guys? Thanks for any thoughts
Edit: Its only done about 45k miles
