Craigus432
- Apr 6, 2010
- 15
- 6
Hi
First of all i'd like to say I have the 1.1 SPI fiat Punto MK1 and have carried out some work myself on it. After changing the headgasket months ago the car injector light came on the and the car juddered in time with the injector light very badly as if the injector was blocked I then cleaned the throttle body and it went away. Recently the car juddered very badly this time no injector light came up at all and the light works. Then the day after it struggled to start started and died almost instantly. I then attempted another start where it started and ran on 3 cylinders then cut to 2 and died. Then it wouldn't start for ages turnign over for about 2 mins and when it did an excessive amount of black smoke came out and felt like it was running on 3 cylinders again but kept it at high revs and it felt normal again after about 2 minutes and ran perfectly. I have been trying to work this out for a while now and have done the following:
Compression Test all came out fine
Spark Plugs are arcing nicely
Cleaned Throttle Body
Timing Correct
Also no oil or coolant loss
Also I have noticed my fuel pump on the ignition is always running but I am unsure if this has anything to do with it as earlier it started perfectly with this issue. Also half the time the code light is on and then other times it is not on and everytime I try to explain how its running awfully in person or how it keeps dying it starts perfectly which is rather annoying sods law I assume.
So please anyone any ideas?
Thanks in advance
Timing Correct
Thanks in advance
