Old 12-06-2010   #1
brake fluid
I have a fiat puno 60 sx and i just bought some dot 4 synthtic brake n clutch fluid tht any gd?
mikey20 is offline Reply With Quote Quote
Old 12-06-2010   #2
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: brake fluid
Quote Originally Posted by mikey20 View Post
I have a fiat punto 60 sx and i just bought some dot 4 synthetic brake and clutch fluid that any good?
Well it's the right stuff, if that's what you mean.
Eklipze3k is offline Reply With Quote Quote
Old 12-06-2010   #3
Re: brake fluid
Castrol Response Super DOT 4 is a high boiling synthetic brake fluid which far exceeds the requirements of the SAE J1703, FMVSS 116 DOT 3 and 4, ISO 4925 and JIS K2233 specifications. Castrol Response Super DOT 4 Brake Fluid is designed for use in all brake systems particularly those which are exposed to extreme conditions. This product has been formulated from mixed polyalkylene glycol ethers and borate ester together with other high performance additives and inhibitors which give ultimate system protection against the effects of corrosion and high temperature vapour lock.
All conventional brake fluids deteriorate during use.
It is strongly recommended that Castrol Response Super DOT 4 should be changed according to the vehicle manufacturers advice. In the absence of such advice, a 2 year change period is recommended.
So yeah its good **** man!
simondhopkins is offline Reply With Quote Quote
(T) Brake Fluid darkcrstal31 Punto (Mk2/2b) 10 24-12-2008 00:29
(T) Brake Fluid Reservoir + Brake Fluid Question oagra Punto (Mk2/2b) 2 21-10-2008 14:13
(T) Help Brake Fluid jennyd Punto (Mk2/2b) 3 01-04-2008 23:49
(T) My Punto needs Brake Fluid, isit a certain one i must get or any brake fluid will do? keepinitcriss Punto (Mk2/2b) 5 02-04-2007 19:30
(G) brake fluid??? jamie03 Punto (Mk2/2b) 7 30-01-2007 16:09
