![]() | #1 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | hi i'm new and having problems with my punto mk2 hi there i'm new here newa i've got a fiat punto mk2 1.2 8v 2003 model and i'm having problems with wen i start the car the engine is v rough. n if i tap the accelerater lightly the car will stall. can ne1 shed some lite on wots wrong with my car or it its just a standard fault with the punto??? cheers ![]()
![]() | #2 |
![]() | Re: hi i'm new and having problems with my punto mk2 does it go away when teh ca warms up ??
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm |
![]() | #3 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | Re: hi i'm new and having problems with my punto mk2 yeah it goes away after it gets warm but the problem is getting it started :P
![]() | #4 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | Re: hi i'm new and having problems with my punto mk2 ![]() IT COULD BE YOUR SPARK PLUGS DOS IT JUDER ALOT
![]() | #5 | ||
Sei Sporting abarth Join Date: Mar 2007 Location: Kent
Posts: 1,168 Thanks: 22 Trader Rating: 0 ![]() | Re: hi i'm new and having problems with my punto mk2 May be throttle plate gummed up - clean inside throttle body with carb cleaner around throttle plate see if it's ok then
![]() | #6 |
Posts: 253 Thanks: 1 Trader Rating: 0 ![]() | Re: hi i'm new and having problems with my punto mk2 I AM NEW TO THIS SITE AND I NO A COUPLE OF THINGS ABOUT FIAT GOT ONE MY SELF AND IF YOU NO HOW TO FIX THE MAIN FAULTS ITS A GOOD CAR BELEVE IT OR NOT ![]() IT COULD BE YOUR SPARK PLUGS DOS IT JUDER ALOT ![]()
__________________ CAUTION, i may talk crap ![]() w/2000 1.2 8v elx |
![]() | #7 |
Posts: 83,497 Thanks: 1480 Trader Rating: 10 ![]() | Re: hi i'm new and having problems with my punto mk2 dont think the op cares no more Last Activity: 20-07-2005
__________________ “The further a society drifts from the truth, the more it will hate those that speak it.” |
![]() | #8 | ||
Posts: 3 Thanks: 0 Trader Rating: 0 | ![]() hi dos any no y the accelerator cable is sticking and were it is on a punto 2001
