Here is the pinout of ECU type IAW59F-M2 (single Lambda sensor)
A1 Not connected
A2 Not connected
A3 Throttle valve position sensor
A4 Not connected
A5 Coolant temperature sensor
A6 Knock (detonation) sensor (+)
A7 Not connected
A8 Knock (detonation) sensor screen
A9 Idle actuator control (stage C)
A10 Ignition coil control (cylinders 2-3)
A11 Not connected
A12 Not connected
A13 Absolute pressure sensor
A14 Air temperature sensor
A15 Knock (detonation) sensor (-)
A16 Not connected
A17 Idle actuator control (stage A)
A18 Idle actuator control (stage D)
A19 Idle actuator control (stage B)
A20 Throttle position potentiometer and air temperature thermistor
A21 Not connected
A22 +5V air temperature thermistor supply
A23 Oil pressure switch
A24 Not connected
A25 RPM and TDC sensor (+)
A26 Fuel vapour canister solenoid control
A27 Cylinder 4 injector
A28 Cylinder 1 injector
A29 Coolant temperature sensor earth
A30 Not connected
A31 Not connected
A32 +5V throttle position sensor supply
A33 Not connected
A34 RPM and TDC sensor screen
A35 RPM and TDC sensor (-)
A36 Cylinder 2 injector
A37 Cylinder 3 injector
A38 Ignition coil control (cylinders 1-4)
B1 Not connected
B2 Not connected
B3 Not connected
B4 Control unit supply (+30)
B5 Not connected
B6 Fuel pump relay control
B7 Not connected
B8 Radiator fan 1st speed relay control
B9 Not connected
B10 Not connected
B11 Lambda sensor heater
B12 Air conditioner compressor relay control
B13 Not connected
B14 Not connected
B15 Not connected
B16 Serial line K
B17 Key signal (+15/54)
B18 Radiator fan 2nd speed relay control
B19 Not connected
B20 CAN-bus B (low speed)
B21 Not connected
B22 Lambda sensor signal (+)
B23 Not connected
B24 Not connected
B25 Not connected
B26 Not connected
B27 Air conditioner activation signal
B28 Fan 1st speed signal request (trinary)
B29 CAN-bus A (low speed)
B30 Not connected
B31 Not connected
B32 Lambda sensor signal (-)
B33 Not connected
B34 Lambda sensor screen
B35 Not connected
B36 Not connected
B37 Not connected
B38 Fan 2nd speed signal request (quadrinary)
C1 Earth (this is the single wire earth connection)
red
A1 Not connected
A2 Not connected
A4 Not connected
A7 Not connected
A11 Not connected
A12 Not connected
A16 Not connected
A21 Not connected
A24 Not connected
A30 Not connected
A31 Not connected
A33 Not connected
B1 Not connected
B2 Not connected
B3 Not connected
B5 Not connected
B7 Not connected
B9 Not connected
B10 Not connected
B13 Not connected
B14 Not connected
B15 Not connected
B16 Serial line K
B19 Not connected
B21 Not connected
B23 Not connected
B24 Not connected
B25 Not connected
B26 Not connected
B30 Not connected
B31 Not connected
B33 Not connected
B35 Not connected
B36 Not connected
B37 Not connected
red
