| Thread Tools |
![]() | #1 | ||
Posts: 213 Thanks: 3 Trader Rating: 0 ![]() | Tyre pressure I had some toyo tyres fitted on my punto Toyo T1-R's 15" What should the tyre pressures be?
![]() | #2 |
Posts: 82,454 Thanks: 1458 Trader Rating: 10 ![]() | Re: Tyre pressure 35 front 33 rear (psi) 35 all round if car fully loaded
__________________ |
![]() | #3 | ||
Posts: 213 Thanks: 3 Trader Rating: 0 ![]() | Re: Tyre pressure
![]() | #4 |
Posts: 82,454 Thanks: 1458 Trader Rating: 10 ![]() | Re: Tyre pressure all the edges of your tyres will wear out and you will use too much petrol if you do that, trust me am running 15" toyos on 2 of our puntos, one for quite a few years
![]() | #5 |
Posts: 23,462 Thanks: 1147 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Tyre pressure The lower pressures are for safety of handling. At the higher pressures the car will feel more 'pointy' Cheers SPD
![]() | #6 |
Posts: 82,454 Thanks: 1458 Trader Rating: 10 ![]() | Re: Tyre pressure they go side ways round roundabouts with the low presure
![]() | #7 | ||
Posts: 503 Thanks: 19 Trader Rating: 0 ![]() | Re: Tyre pressure Isn't that the correct method of negotiating a roundabout then? Full speed in, steer in and lift off, steer with lift-off oversteer until pointing in roughly the right direction and then opposite lock and a boot full of accelerator? Or have I just been playing too much Gran Tourismo?
Thread Tools | |
![]() | tim1989 | Punto (Mk2/2b) | 6 | 13-07-2008 12:05 |
![]() | lee8040 | Punto (Mk2/2b) | 2 | 20-01-2008 03:16 |
![]() | porket | Punto (Mk2/2b) | 3 | 02-05-2007 19:54 |
![]() | Ste Unit | Bravo / Brava | 3 | 06-03-2006 00:20 |
![]() | Cinquelover | Cinquecento / Seicento | 2 | 19-02-2006 23:02 |
