Old 18-04-2010   #1
rough idle when warm and oil leak
My mk2 punto 1.2 8v (2003 / 53 plate) had been juddering whilst driving for a while, seemed like dodgy spark plugs - so replaced these and the problem got much better. Only occasional juddering since.
Problem seems to have shifted now though, it runs great when cold - but once it gets warm and i'm waiting at lights it judders horribly, also occasional juddering when accelerating from roudnabouts etc. I had a look under the bonnet (not that i had any idea what to look for) and i've noticed what looks like an oil leak, its on the right hand side of the engine as i look at it. Right at the top of the engine (just below the plastic air filter cover).
Could this be a cause / symptom of my problem?
I can take pictures if i've not described it well.
Andrew
andyathome is offline Reply With Quote Quote
Old 18-04-2010   #2
Re: rough idle when warm and oil leak
so the oil leak looks to be the rocker cover gasket, i'm off to wilco to get one.. and try to install it. but is it possible this is the cause of the misfire or will i have to look elsewhere to fix this?
thanks
andrew
(T) Oil leak and poor idle seicento8483 Cinquecento / Seicento 5 08-03-2010 15:40
(G) Driveshaft Seal Oil Leak/Knocking over rough tarmac Jackoh Cinquecento / Seicento 4 10-07-2008 17:03
(G) Rough Idle BenW Panda (Classic) 17 23-06-2008 12:49
(T) Desired Idle revs, rough idle, slack throttle cable? ronnieronson Cinquecento / Seicento 13 15-09-2007 10:18
(T) Rough Idle fiat81 124 Spider (Classic) 1 18-11-2005 17:31
