Hi
Does anyone know where the vacuum hose is located on a MK2b 1.2 8v engine?
OK, you don't want to be tapping into the servo hose then.
Why do you want a vacuum gauge?
SPD
Explain how a vacuum gauge is going to help your fuel economy? The fual rail is contantly pressurised at the correct ratio to what the inlet manifold pressure is. Fuel economy is based on your driving style and the engine, suspension system, drive train condition, and tyres along with alot of other things.
The gauge displays intake vacuum, which is an indication of how much load is on the engine. The lower the vacuum reading, the higher the load on the engine and the more fuel it burns.
The gauge saves gas by helping the driver see the effect his right foot has on fuel consumption. Tromp down on the gas pedal and intake vacuum drops and fuel consumption goes up. Take it easy on the gas pedal and accelerate slowly causes less of a drop in intake vacuum and less fuel usage.
