Old 22-03-2010   #1
Various electrical problems - Help!
I have a 2003 Punto Active 8v and have various electrical problems and would be grateful if anyone can assist. I have had a scan carried out but it showed nothing and have also checked the lamps on the car.
The problems are as follows:
1. When slowing down (below 10mph) and when stationary, the electrics will cut out. Sometimes coming back on, sometimes not.
2. When indicating right, the dashboard "lampbulb" light on the dashboard comes on.
3. When indicating right and breaking the indicator will double flash/click as well as the dashboard "lampbulb" light comes on.
4. When generally breaking the dashboard "lampbulb" light comes on.
5. Occasionally, the "key" light on the dashboard comes on.
6. The "airbag" light on the dashboard is permanently on.
Thanks in advance!
EmilyH1 is offline Reply With Quote Quote
Old 22-03-2010   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Various electrical problems - Help!
Time to check the earths.
Basically all of them, by the sounds of it.
Undo, clean, abrade, clean, refit, clean, tighten firmly, clean, apply grease.
SPD
Old 22-03-2010   #3
Quote Originally Posted by rallycinq View Post
SPD
Thanks for replying
As I'm complete novice to all of this, would anyone be able to point me in the right direction or explain how to check the earths??
Old 22-03-2010   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by EmilyH1 View Post
Thanks for replying
SPD
There will be an earth behind each set of lights, one under the dash and at least one engine to chassis, then the battery to chassis one.
SPD
Old 23-03-2010   #5
Thanks a lot will have a go of this.
Thanks!
Old 24-03-2010   #6
The worrying one is losing electrics when braking. By "electrics" do you mean things like lights or is it engine cutting out as well?
The earth points on a Mk2 Punto are (according to Johnny Haynes):
E1 - At battery terminal (-)
E2 - Left hand inner wing
E3 - Left hand inner wing
E4 - Left hand inner wing
E5 - Right hand foot well
E6 - Left hand side of luggage compartment
E7 - On gearbox
E8 - Left hand inner wing
Each point has one or more wires connected to the metalwork of the car (it uses the body instead of needing more wires to get the current back to the battery).
There may also be localised earth points near light clusters. Some of your symptoms have "indicating right" in common so you may want to start around the front and rear offside lamp clusters.
Make sure the battery connections are tight first.
The airbag light might be on because a fault has been detected (common problem on this model). If this is the case, it can't be turned off without some diagnostic equipment. Getting that done professionally will cost significant hard-earned stuff. You might want to have a look at FiatECUScan.net and see my posting on cheap ECU reader elsewhere on this forum (an ECU reader that apparently can be adapted to read/reset airbag controllers)
red
red is offline Reply With Quote Quote
Old 25-03-2010   #7
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Problems 2 3 and 4 could also be linked
The Bulb out light - yes could be caused by the earthing issues, but it'd be worth while checking that all your brake lights and idicators all work as well
(while your at it check all your lights work - Get a friend - Family Member to help)
But to me with all the faults earthing and bulb checks are defo the 1st move to make
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 25-03-2010   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by Ziggy122 View Post
Ziggy
I presume the OP carries out a weekly lights check as everyone else does on here.
I find supermarket windows handy for checking the brake light are working.
My leg is not long enough to press the pedal and look at the back of the car at the same time.
SPD
Old 25-03-2010   #9
I do Cheat i use a window as well to see if i have a reflection off the lights
Another Cheat is Camera Phones - Record what you do remember what you did - and watch video back you'll see whats working and what isn't
Just knowing how funny punto's can be with a bulb been slow to "wake up" Can often trigger the bulb out light
Ziggy
Meet Bumble-Bee
Old 28-03-2010   #10
I would be interested to find out what the problem was if you solve it, my wife's punto has the lamp failure lit but all the side lights, tail lights, brake lights, number plate, low/high beam and indicators all work fine
stevePil is offline Reply With Quote Quote
Old 29-03-2010   #11
Quote Originally Posted by stevePil View Post
Does it go off after a while?
or is it on constantly?
Also check the wattage of bulbs - if you put a lower Wattage bulb in - it often lights up
Ziggy
Meet Bumble-Bee
(T) Electrical problems I think dipole Panda 19 20-09-2008 15:52
(T) Electrical Problems Mavis Grande Punto 22 29-11-2007 23:17
(T) Electrical Problems! arc Cinquecento / Seicento 2 02-05-2005 13:18
(T) electrical problems??? nothappy Punto (Mk2/2b) 3 16-03-2005 01:16
(G) Electrical problems b00m Uno 2 06-02-2005 11:15
