Thread Tools
Old 17-01-2005   #1
how do i make my wipers run smooth?
any tips? ...they wont stop screeching across the screen! ahhh
nickphonics18 is offline Reply With Quote Quote
Old 17-01-2005   #2
Sweden
Re: how do i make my wipers run smooth?
I have the exact same problem whith my mk2! Itīs very annoying . But I cheked whith my Fiat service, and they told me itīs a very common problem on Puntos. And the only thing that helps is to spray the electonic contacts which goes to the wipers. Iīve done it three times now but it keeps comming back after a while. Does your wipers run smooth after a few minutes? Mine does!
Used to have: [I]Fiat Tipo 1,6 Sx -95[/I]
Now: [I]Fiat Punto 80 16v -02[/I]
[IMG]http://www.fiat500club.nl/images/topleft/tlstart.jpg[/IMG]
Italiano Lover is offline Reply With Quote Quote
Old 17-01-2005   #3
Sweden
Is it only in position one they do like that?
Old 17-01-2005   #4
Trader Rating: 1
had the same problem, sprayed contacts loads of time no joy, changed wipers, no joy, then i bought some supurbe quality bosch wiper-blades and it stoped! dont ask me why and how.
bhinderharminder is offline Reply With Quote Quote
Old 17-01-2005   #5
The Negotiator has donated!
Different rubber, always buy good blades it makes a huge difference.
Now drives: BMW 635d (wow!)
Past:
Renault Laguna Coupe GT 180. Laguna Initiale dci. 52 Megane 1.9dCi, Y-reg Fiat Brava JTD (Pale Blue) (2006), '51 Fiat Brava 80 SX (black) (2006), M-reg UNO (2003-2004)
The Negotiator is offline Reply With Quote Quote
Old 18-01-2005   #6
Trader Rating: 10
dave has donated!
there something about re-greesing the gears on mk2 wipers in other threads,
Old 18-01-2005   #7
its on all the speeds even when its raining alot the wipers screeeeeeetch across the screen have put music up as drive me crazy. so wot a good make wiper blade and where can buy it from? mine used to judder but fixed that now thanks to that guide
Old 18-01-2005   #8
This is a common problem it seems on most punto's. I spoke to someone at local fiat garage and they said it was the grease being to heavy causing a bad contact. Check the forum though as I'm sure I remember a thread where it described in detail how to fix the problem (no haynes manual required)
Fiat Punto Sporting 1.2 16v - Sold
Ford Escort Estate 1.8 16v - Sold
Fiat Brava 1.4 12v
rongo is offline Reply With Quote Quote
Old 18-01-2005   #9
Trader Rating: 10
dave has donated!
i use Ģ1 a pack wipers from market and clean them with washingup liquid before fitting, no screaching
Old 18-01-2005   #10
Burninator of threads!
faster4_tec's Avatar
faster4_tec has donated!
Mongolia
Yep same here.
Buy a few lengths of blades from the local car shop at a few pounds and replace the front blades every 6weeks or so.
And replace the cardrigde every year or so
faster4_tec is offline Reply With Quote Quote
Old 20-01-2005   #11
I had a problem with my Punto HGT, the wiper motor had to be changed, the old one was just not up to the job - wipers juddered across the screen. Was told by the dealer that this was covered by a Fiat "recall"
fatboyslimfast is offline Reply With Quote Quote
Old 22-01-2005   #12
wipers run nice and smooth now....i bought a bosch 11.99 wiper from halfrauds. clipped it on.......silence!! now find out if it still be silent in the rain....
Old 23-01-2005   #13
Quote Originally Posted by fatboyslimfast
That's correct fatboyslimfast, this happened to me a couple of years back now, my missus had a 51 plate Punto GO!, and the wipers started juddering. I changed the wipers but it did not work so I took it back to Fiat who informed me that it was a known fault with the motor (Something about the grease in the gears being too thick), anyway the motor was replaced under warranty.
As I have an 02 HGT I asked the service guy if they were recalling all Puntos so that I could get mine done, he said that Fiat did not know which cars had the dodgy motors and as it would cost a lot of money to recall every single one they were just relying on people to come in and report the probelm, then they would fix it.
Broom Yellow 2002 HGT.......mmmmmmmmm! nice.
evanjohn00000 is offline Reply With Quote Quote
Old 24-01-2005   #14
Try Champion wipers, they might judder at first but are excellent wipers. No smudging or screeching.
Punto Active 1.2/04
thomash is offline Reply With Quote Quote
Old 09-02-2005   #15
Sweden
I have my car at my local Fiat garage for the moment to change the whole wiper kit (I suppose wipermotor). Because it doesenīt work after several attempts to fix it. But itīs on the warranty
Thread Tools
(T) Wipers Not Moving! fahema Punto (Mk2/2b) 10 19-04-2005 14:52
(T) wipers judder?! nickphonics18 Punto (Mk2/2b) 17 20-12-2004 14:38
(T) Brava Intermittent Wipers not working zwyzyk Bravo / Brava 4 19-10-2004 14:33
(T) front wipers gone mad Bradford_HGT Bravo / Brava 1 26-07-2004 21:37
(T) [cinqo] wipers Fiat Powerrr Cinquecento / Seicento 8 28-11-2003 22:10
