Punto Maltese
Hey
I curently own a Fiat Punto ELX, 1.2 8V engine, 2002 model. Its been running for these 3 years absolutely trouble free, and I really drive it hard. However, 2 days ago, i jumped into my car, and I know, to my carelessness, did not give the oil time to warm up, and strarted to rev the engine all the way to 5,000 rpm, with the outside temperature at the time being around 8 degrees Celcius and the car had been along time outside. I was in a hurry and just was careless.....
At one point, i went to perform an engine break as a I approached a roundabout, but as I engaged the second gear, the car seemed to lose half of its torque, and came out of the curve really, really slowly. It started to do a funny noise as well, similar to a FIAT 500`noise (the original one, produced in the 19601s ) and when the car was in neutral, at a standstill, it vibrates quite a bit, and obviously, its torque remained the same since the incident, it seems as if it has halfed, literally. When I took the car to our mechanic, not the FIAT garage, coz my warranty has expired and I know a very good mechanic, he told me that mechanically, the car is still as good as new and perfect, but the glitch was probably an electrical one with the car`s ECU, and sent me to an electrician, which I will be visiting tomorrow.
I was thaen speaking to a freind of mine who is to graduate in mechanical engineering this year and told me that it may be a safety device within to ECU to switch off a piston, or do something similar in order to prevent a head gasket failure or any other damage to the car.
Does this model have such a feature?
If not, what could possibly have gone wrong? The mechanic told me that probably it sparking on an electrical coil less, i.e. one of them may have gone wrong
Btw, cheers to a very good site, it has everything a Fiat owner or an enthusiast should know !!!! Well done guys
