General Removing trim between windows. Help please.
Ive seen many of the euro cars with these pieces removed, i wanted to do that today.
Just wondering the best way of doing it... Is it just like removing the side bump strips?
And will it leave any holes that need filling?
Thanks, Jake.
WD40 works well too. :)
Finished this earlier, just gotta work on the sticky stuff. I will try WD40 if you say so, cus i have nothing else really other than autoglym bumpercare.
I thought it was the clearcoat peeling off but luckily it was just glue.
Thanks Jake.
yep wd40 does the trick,spray it and leave it overnight (y) then skoosh it again before you tackle it
Jizer engine cleaner (not Gunk) is also good and its water washable. But it does take off body wax, so don't slosh it around.
