Old 14-02-2010   #1
Turkey
Magneti Marelli Battery
I have a Fiat Punto 1.4 16 V New Dynamic vehicle. Model year is 2005.
I'm from Turkey.
My battery (accumulator) is weak. So I'm looking for a new battery. In the engine, there is a Magneti Marelli battery. Here is some specs that I can found from batteries outside :
Magneti Marelli
12V 44AH 250A
560250-STS
Dimensions : Width : 175 mm, Length : 175 mm, Height : 190 mm.
This battery is also known as "cubetto".
But I couldn't find this battery in Turkey, neither Fiat Services nor local producers.
Is there a provider in Turkey that I can purchase or order this product? Or is there a way to purchase from an offical dealer?
This is an unusual battery I guess because there is no battery like this in local producers.
Can anyone help me?
serdarce is offline Reply With Quote Quote
Old 14-02-2010   #2
Re: Magneti Marelli Battery
Just get a battery that fits into the battery box. I have a Bosch SIlver which needs a block of wood under the securing strap.
DaveMcT is offline Reply With Quote Quote
Old 14-02-2010   #3
tinytim has donated!
I agree; just get one that fits and has the correct connections on the correct side; don't worry about the ampere hours.....
tinytim is offline Reply With Quote Quote
Old 15-02-2010   #4
Turkey
Thanks for answers guys. I'm looking a battery which fit in the box. I don't want to use a battery which is not suitable. I don't want to use a piece of wood etc on the battery. So, I need exact battery as same original battery. Don't you find original size battery?
Old 15-02-2010   #5
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Bosch list a battery with the correct specification and size for your car.
Here's a Turkish version of the Bosch catalogue.
http://ecat-online.bosch.de/toc/tr/0...dexFramesetJsp
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 15-02-2010   #6
The Bosch "Silver" battery (cells contain silver) is physically smaller than the original, but has a higher charge capacity. I could have used a cheaper one that has less weight though about the same size. The cheaper version has a 2 year warranty. The Bosch is 5 (or maybe 6 years). I decided the additional 20 was cheap insurance against an early battery failure.
In the end its down to cost and performance. Physical size (as long as it fits the car) is irrelevant.
Old 17-02-2010   #7
Turkey
Thanks again for the answers. I always want to use original speare parts on my car. That's my character
I couldn't open the web page of Bosch. Can you send me the product and/or catalog name and number? So I can see the product and order one for me from Turkey.
Old 17-02-2010   #8
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
This is from the Bosch catalogue.
Name:	Punto Bosch Bat1.JPG
ID:	74062   Click image for larger version
Name:	Punto Bosch Bat2.JPG
Old 17-02-2010   #9
You probably cannot buy the original any more because the design will have improved since the car was built. There is also the fact that original parts are often only enough to get through the warranty period. The Bosch Silver is much better quality than the original or for about 20 less you can have a battery which is about the same.
Old 18-02-2010   #10
Turkey
Hi guys,
Thanks for he answers. This is very useful for me. By the way, I found the same battery (as size and electric) on Varta. Now, I have 2 alternative to buy. Thanks !
Ok, then, Are there problems on this vehicle on long term use. My car is 2005 and about 35.000 km. What is your opinions?
Old 18-02-2010   #11
These cars have electrically assisted power steering which is most needed at low speed and where a weak battery can cause problems. Its therefore best to go for the best quality battery.
Long term, make sure the coolant and oils are are changed and replace the camshaft belt is replaced according to the service schedule. If many short journeys are driven change the oil more often.
Apart from that all you need to know is on this discussion panel.
Old 19-02-2010   #12
Turkey
Thanks for all for your kindly help
(G) Help got issues with magneti marelli distributor pudsey Panda (Classic) 12 09-03-2012 12:39
(G) Magneti Marelli for 1.2 500? Murano16v 500 2 12-02-2010 13:03
(G) Magneti Marelli decoding freddymey Ulysse 0 27-01-2009 20:44
(T) Distributer Magneti Marelli JoseMatos Uno 2 24-12-2007 03:11
(T) Magneti Marelli parts for Brava, where? TheCROW Bravo / Brava 12 11-01-2006 10:50
