Old 07-02-2010   #1
knocking noise from the rear?
Anyone know what this could be?
I thought it was the shocks as i knew they were a bit weak, so had them replaced but it still knocks a bit going over potholes etc, not really bad but a bit annoying. It seems to be the right side.
I asked my mechanic if it was the radius arms or rear bushes but he said they looked ok (?).
Any help would be greatly appreciated!
N344HLU is offline Reply With Quote Quote
Old 07-02-2010   #2
phil11_uk has donated!
Re: knocking noise from the rear?
It might be your exhaust hitting the top of the rear axle
phil11_uk is offline Reply With Quote Quote
Old 07-02-2010   #3
MikeSalt has donated!
Sometimes third-party exhausts are not bent to exactly the right geometry. I had a knock from the rear, and I tried to hunt it down, fixing a loose heatshield, replacing exhaust rubbers, padding the handbrake cables with foam, replacing a cable-tie with the proper handbrake cable clip etc... I still had the knock, then I had a new backbox and mid-section, and the sound went away. The previous exhaust must have been bent a little bit wrong, causing it to knock the chassis as it bounced around.
MikeSalt is offline Reply With Quote Quote
Old 09-02-2010   #4
awwwwww nooooo.....
I have the same thing, sounds like 'shoes in a dryer' sort of knocking, but mainly when I turn right with one or more passengers in the car
And I just bought two new shocks for the back
And I had a new exhaust fitted a couple months after I bought the car, and therefore a couple months before the knocking started
Dang... oh well I only paid 40 for both and my friend is fitting them for a bottle of whiskey i didn't really want
Suffering a strange knocking Noise :bang:
Punto MK2 8v Rosso Sicilia
SgtMunky is offline Reply With Quote Quote
(G) Rear knocking noise - yes I know we've heard it all before but.... Phil_ Cinquecento / Seicento 13 03-01-2008 15:26
(T) Knocking noise at rear of cinq... littletinyone Cinquecento / Seicento 6 09-02-2007 21:33
(T) high pitch noise from engline and knocking noise in rear elcrack Punto (Mk2/2b) 12 08-11-2005 21:53
(T) Knocking noise from rear wheel dobson2k Bravo / Brava 0 14-09-2005 12:12
(T) Help knocking noise from rear stevehickey6 Punto (Mk2/2b) 21 13-10-2004 05:11
