Old 04-02-2010   #1
Fiat punto elx not starting and warning lights
Hi
I have solved quite a few problems with the help of this forum and I have got yet another one.
The past couple of days the car has taken a while to start although starting and then having no problems for the rest of the day. However, last night after around 5 minutes of driving it the red steering warning light came on, this went off 5 minutes later and when I tried to start the car later that night there were no problems at all.
This morning it again struggled to start and after 5-10 minutes of driving the red steering light came on again and a light which looks like this apart from red showed up. [IMG]file:///C:/DOCUME~1/Gordon/LOCALS~1/Temp/msohtml1/01/clip_image002.jpg[/IMG] only every now and again though. The car then juddered quite a bit. I decided to end the journey there and return home and phone in work. I try starting the car a little while after returning home and it now won't start in a way that it seems like it has no petrol (it does ) or the battery is flat. I have tried to jump start it but every time i get it started and think it will be fine the car drops its revs and cuts out.
please somebody help me.
thank you for taking time to read this long thread, I know you must have better things to do but I just wanted to include everything
Cheers.
wilson999888 is offline Reply With Quote Quote
Old 04-02-2010   #2
Re: Fiat punto elx not starting and warning lights
Just noticed my picture didnt work. it is here and is just to the left of the battery light as you look at it apart from mine is red not amber/yellow. thanks. http://ic1.maxabout.com/autos/cars_i...009-6-18-7.jpg
Old 04-02-2010   #3
smithmr8 has donated!
My car's steering light comes on occasionally. But the steering feels fine. Then again, my car's ECU is faulty, and could ideally do with replacing. E.g. My airbag failure light is on. ECU Was reset by fiat, but it came back on shortly after. Can't really justify a 400 ECU change atm though.
Maybe the problem with yours ?
smithmr8 is offline Reply With Quote Quote
Old 04-02-2010   #4
OK then cheers, might disconnect the battery for a little while then and see if resetting it will have any affect, be worthwhile if it starts so I can get it home and have a proper look at it (at a friends at the minute).
Old 04-02-2010   #5
I like to be different!
bredsticz's Avatar
Trader Rating: 1
bredsticz has donated!
New battery needed, that will cure your steering problem, if you have the car running untill its warm does it run fine? If so get the throttle body cleaned and should be fine!
Any MK2 punto parts needed? Let me know!
I have 2 punto's worth of parts for sale
bredsticz is offline Reply With Quote Quote
Old 04-02-2010   #6
hi cheers for the reply, I cant get the car to start at all now, but when it did cut out it was after a journey so should be a little warm I would have thought. somebody is gonna take a look at 5:00PM so I will let you know if there is any look with that.
(T) Punto 2001 (Y) 1.2 8v ELX Not Starting Carlospunto Punto (Mk2/2b) 5 24-12-2008 22:54
(T) punto elx jtd 1.9 starting problem steve earle Punto (Mk2/2b) 7 26-05-2008 16:31
(T) Warning lights on when starting RichDoblo120 Doblo 13 05-05-2007 13:22
(T) Fiat Punto 1.2 X Reg 2001 Hazard Warning Lights Come On When Car Is Parked NattyBuck Punto (Mk2/2b) 1 10-04-2007 18:07
(T) Fiat Brava 1.8 ELX Grating noise after starting . Mario Ruiz Bravo / Brava 3 07-01-2004 23:33
