DeathMarkedLove
- Apr 23, 2009
- 14
- 5
OK, lets see if i can get everything correct.
I had a water noise behind the dashboard and thought nothing of it.
Not long after the headgasket went. (This was about a week ago)
I had a new headgasket, cambelt and thermostat (cambelt and thermostat apparently became "contaminated" due to the way the gasket blew)
I never noticed the running water after the job was done, and now i can hear it again.
I am going to bleed it tomorrow by leaving the cap off where you top the water up and running the car with the heaters going etc (So i read)
I rang the garage today and he said some cars do make water noise and that it is fine.
He said there is no temp gauge on mine which there isn't and that a warning light should come on if there is any overheating.
To which i said there was no light that appeared on the dash when the head gasket went, he said to check it. From what i know it looks like a thermomator in water, which does light up when turning the key to the first position.
So as far as i know that light is working. I will repost tomorrow when i have bled it to see if it goes away, and if it does, i can gurantee it will happen again, so what could it be letting air in?
Cheers in advance, im tired and hope i got everything in here to help people.
