I have same problem since i bought the car last JUNE i have put in 12 headluight bulbs they just keep blowing!!
Iv check alternator and it is fine producing the right voltage is there anything else that is causing it just today another bulbs has blow my main beam drivers side???
Im not using cheap bulbs either i keep buying expensiver bulbs each time but no luck
No, the only time resistors were incorporated into the circuit was for Dim-Dip headlamp that were a legal requirement in the UK in the mid 1980s.
A relay and a resistor would supply the headlamp bulbs at 6v whenever the sidelamps were switched on. Even with Dim-Dip, if the resistor went open circuit there would be no power to the bulb and if it shorted, the bulb would revert to normal 12v supply.
