Styling Bumper Grille replace with mesh
Peterborough
Hey,
I want to put mesh on my bumper so i can get some cold air into my engine,
is it easy to remove the front bumper on a car ?? if so what do you doo
and what can i stick the mesh down with ??
please reply thankss
garage_attachment.php
The three bottom grilles on the bumper :)
I think you should have grills in at least the centre one.
Be careful, the wrong mesh can cause more problems than it solves.
Needs to have holes in it big enough to get the air in without increasing turbulence. Too small a hole in the mesh and no cooling air will be able to enter.
I understand that most people who haved fitted mesh use tiger seal, sikaflex or similar.
On mine I have a wide mesh with an even wider stronger mesh as the backing. Mine is tie wrapped in.
SPD
SPD
Ahh okay then thankyou,
i never thought about turbulance actually, i need to make sure the stuff i buy is okay,
i have tigerseal, ill have to use that,
thankyou for your help
