chris10988
- Jan 24, 2010
- 4
- 1
Hi all, my 1st posting ever so please be patient. I have an issue with my mums Fiat Punto 1.2 8v 2002:bang::bang:. Intially the problem was over heating and the head gasket went due to a faulty water pump which had somehow broken all the plastic impellar blades. I changed the water pump and the head gasket, I didnt have the head skimmed as it didnt seem warped when I looked at it. I then timed the engine up and fired her up. I left it running 15mins until the temp sensor went to warm on the dash, It wasnt over heating and then the enigne just cut out, it almost stalled but it wasnt in gear. I then kept trying to fire her up, and eventually there was so much pressure in the engine it blew the rocker cover (while I was stood over it, Iv never run so fast ). So I took the head back off and there was water in the 2 middle cylinders. This led me to believe the head was warped and boiling water in the cylinders thus not creating combustion but only steam and pressure, so I had it skimmed and presure tested yesterday and fitted a new head gasket this morning and re-timed it. The engine will still keep back firing, it spits tiny flames out of the intake. The spark plugs smell of unburned petrol so the injectors are working fine. I have even had a Volvo mechanic look at it and I had him baffled.....Can anybody else tell me what is going wrong? It isnt the valves stuck in place as I have turned them and seen them all moving. The next one will be to test the prssure in the Cylinders with a gauge but after that I am totally out of ideas:idea:......Any help would be appreciated please...Thanks in advance..Kind Regards Chris....
(FIAT) Failure In Automotive Technology.
