L2wis...i'm bit strapped for time right now mate but here goes...
I used axle stands under the front simply to save my back lol and a small trolley jack (wooden block also) to support the engine under the sump.
I used a long screwdriver down the plug hole of cyl number one to determine top dead center rather than the marks which are so hard to see. Just rock the crank pulley forwards and backwards over and over until the screwdriver shows you where the top is.
New belt will have timing marks on it and a directional arrow. Line up the belt so that the lower mark is alongside the mark on the oil pump (top dead center as above) and slip belt over the whole rig and make sure the cam pulley/sprocket lines up at the second mark on the belt. Its much easier to do it this way due to very hard to see marks IMHO.
When it comes to the belt tension...like others have said its a bit hard to describe but its no where near as tight as you'll think it should be. Also, daft as it sounds you'll know its too tight if it hums when you run the motor. Mine didn't hum at first but did do once the engine was hot because (honestly lol) the motor grows taller very slightly and tensions the belt that little bit more.
So..be prepared to have to back off the belt tension a couple of times until its not slack but will not hum/hiss when it runs with hot engine. (even Fiat tech said to me thats all they do).
Lastly...watch how tight you do up the top mount bolts as the go into an aluminium head that is surprisingly delicate. Maybe consider a dab of threadlock on each bolt and go steady on the ratchet.
Good luck mate, if you where nearer i'd come and help
Edit...thought i'd read Manchester as where you lived. If you near Hull gimee a shout
