Thread Tools
Old 02-01-2005   #1
Removing window crank handle
I'm trying to remove the panel on the drivers side door of my 3-door 95 punto. However, I can't work out how to remove the window winding handle - in my Haynes manual it skips this step altogether and only talks about electric window models!
I can prise open a gap between the handle and the collar that sits against the door panel, and I see what could be the horseshoe bracket that I've been told about. But I can't work out how to remove it or what to do next.
I'd really appreciate any help with this problem - it's driving me nuts.
Thanks,
lsteele is offline Reply With Quote Quote
Old 02-01-2005   #2
Trader Rating: 10
dave has donated!
Re: Removing window crank handle
welcome to the forum
you get piece of rag and put it in the gap, then pull rag back and forth and the clip will ping off. to refit simply fit the clip to handle before fitting it then press handle on.
Old 02-01-2005   #3
What? Just pull, it eventually comes off.
I feed my cat
PuntoRob is offline Reply With Quote Quote
Old 02-01-2005   #4
Trader Rating: 7
CTD Curling Champion, Mini Pool 2 Champion
Suriname
it eventually comes off..... with half in your hand, and half still on the door!
Do it daves way!
chrisunoman is offline Reply With Quote Quote
Old 02-01-2005   #5
Mine came off fine (yes in 1 piece), I don't see what all the fuss is about :shakehead
I feed my cat
Old 02-01-2005   #6
there is a little clip that holds it on to the shaft behind the collar part, the prefered method of removal is to poke the clip off wiith a screwdriver.
-=[Punto sporting 1.2 16v]=-
-=[Ex-fiat tech]=-
kebab is offline Reply With Quote Quote
Thread Tools
(T) rear door window crank removal newportz Punto (Mk2/2b) 14 30-09-2018 18:32
(S) Handbrake Handle Replacement polecat Marea 1 01-11-2006 08:54
(S) Removing rear window Adamski Cinquecento / Seicento 2 28-10-2004 18:36
(S) Removing seat handle on fiat bravo lilman777 Bravo / Brava 8 29-09-2004 12:08
(T) Help needed - removing 'tailgate handle' + walders Bravo / Brava 0 11-04-2003 15:57
