Technical Where's the gearbox oil filler hole on a 1.2 8v please
Halmer
Keele
Wanted to check the gearbox oil level but not sure how to.
1. Where is the hole to fill it?
2. Once I have found it do I just top up until it runs out?
Halmer
Top of the gearbox, right behind the battery there is a black stopper, it's circular. Pull that out and pour in there, no don't fill 'til it comes out! the Level check is under the car, never checked mine before so someone will have to tell you where the level check is
Right behind the battery there is a cream coloured circular stopper that I can spin around but it does not come off easily. Is this the one please?
I assume that if I lever this off there is a big hexagonal allen key type nut underneath?
Thank you.
H
Nope just a stopper as far as I'm aware, yours may be cream, mines either black or very dirty! Just pull it out! Allen key is for the drain plug underneath if you want to drain the old oil out!!
OK thanks.
I'll give it a tug tomorrow when it's light and stopped snowing.(y)
Ahh right that'll be the level check i wasn't sure about then. But the actual filler hole is that stopper I said. Only know because one of my cars has it missing so was getting dirt into my oil making it a bit rough changing gears. Don't know how the hell someone loses that
Pretty tight on though for a breather, and yeah i only noticed mine was missing when it was in the garage and he pointed it out, said it was the filler cap. Maybe he stole it!
Can fill it up from either then but front would be better. Presume that's at the right level to fill to the max aswel!
well i dont really know what its meant to do, but when i done clutch on one of my last puntos i couldnt undo the filler/level plug cos i didnt have all my tools on me, so i just bunged 2L in that hole we speak of and never had any problems :p so it does work as a filler hole but i dont think that is why its there.
OK thanks both.
Need to buy a 12mm key from Halfords or somewhere then.
Cheers.
H:slayer:
