i noticed a loud squeal coming from my driver side brake, its constant, but gets worser when braking, i toolk the wheal off and the disk has been ground down all the way around it in a line around the center. so im assuming there is something stu ck behind the pad or the pad is completly worn. the problem is that i cant remove the pin that holds the caliper in place, does anyone have advice on how to loosen it ? sorry if this is quite simple.
thanks
thanks
