dannyboy2005
This is the situation.
I drove 60 miles down the motorway to my dads works to change the engine over because i had a worn out cam shaft on my engine.
I drove down with no problems at all, and used only £5 worth of fuel so clearly no problems.
We took the engine out swapped the components over from my original engine, sensors, leads, plugs etc.
Fitted the 2nd hand engine which i knew was a good engine as i herd it running before. It was from the same year, same model and even same colour car.
Fitted the second engine, connected all the sensors and timed it up correctly with a new belt and tensioner. Doubled checked everything and started the car. It started on the button and ran for a good few seconds without a problem.
I turned the engine off, checked the engine level oil, restarted the engine and ran ok for a few seconds. Then it developed a slight mis-fire and ran quite un-even.
Turned the engine off, doubled checked the timing which was spot on. The tension on the belt felt the same as before.
We ran it again, it started fine though it had a mis-fire. The longer it ran, the worse it became. No matter what we did to the engine we couldn't eliminate the problem.
It started to puff out white smoke quite badly. So we suspected it had a internal mechanical fault. With that it started getting more and more juddery and cut out on us (After being running for around 1 hour, whilst trying to eliminate faults)
With that we fitted my original engine (Which we knew would work as i drove down using it) using my original components. The engine started fine then developed a mis-fire and again gradually got worse the longer it ran. It then conked out on us (just like the engine i put in earlier)
We don't know why this is happening. All the plugs are fine, new HT leads and coil pack is fine too. The alternator belt is nice and tight with a new alternator and we again checked all sensors.
Can someone tell us what we're doing wrong?
