| Thread Tools |
![]() | #1 | ||
Posts: 21 Thanks: 0 Trader Rating: 0 ![]() | Changing a Reverse light switch??? Hi all, this is my first post on the forum and thought i'd start with a good one. Having found out that my reverse light doesnt work, and having spent time playing with bulbs and fuses i've come to the conclusion my reverse light switch is faulty (had a play with it and reverse light worked for a bit then cut out again). Is it as easy as unscrewing it and replacing it with the new one, or is there more to it?? Any help would be greatly apprieciated ![]()
![]() | #2 |
Posts: 23,469 Thanks: 1148 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Changing a Reverse light switch??? Hi all, this is my first post on the forum and thought i'd start with a good one. Having found out that my reverse light doesnt work, and having spent time playing with bulbs and fuses i've come to the conclusion my reverse light switch is faulty (had a play with it and reverse light worked for a bit then cut out again). Is it as easy as unscrewing it and replacing it with the new one, or is there more to it?? Any help would be greatly apprieciated ![]() Its as easy as you describe. Go for it. Cheers SPD
__________________ |
![]() | #3 | ||
Posts: 21 Thanks: 0 Trader Rating: 0 ![]() | Re: Changing a Reverse light switch??? Thanks mate, i'll get right on that. ![]()
![]() | #4 | ||
Posts: 1 Thanks: 0 Trader Rating: 0 ![]() | Re: Changing a Reverse light switch??? can any1 help me wiht this topic, i have made alot of searches and i cannot find anothing diy on how to fit a new reverse light switch, its not the bulb whihc i have checked, i have not check the fuse, i will do if it is not that, i here that the other option is the reverse light switch, how do i replace it, and where is it. can some1 please direct me on how to do this, thank you
![]() | #5 |
__________________ Black '53 Mk2b Punto Active 1.2 8v Hit the thanks button if you find my post helpful :-) |
![]() | #6 |
Posts: 23,469 Thanks: 1148 Blog Entries: 3 Trader Rating: 1 ![]() | Re: Changing a Reverse light switch??? can any1 help me wiht this topic, i have made alot of searches and i cannot find anothing diy on how to fit a new reverse light switch, its not the bulb whihc i have checked, i have not check the fuse, i will do if it is not that, i here that the other option is the reverse light switch, how do i replace it, and where is it. can some1 please direct me on how to do this, thank you Cheers SPD
Thread Tools | |
![]() | Pull9Gs | X1/9 | 11 | 06-04-2012 12:57 |
![]() | dare | Cinquecento / Seicento | 6 | 04-09-2009 04:55 |
![]() | new2 | Multipla | 0 | 08-08-2009 20:51 |
![]() | new2 | Multipla | 2 | 31-07-2009 22:30 |
reverse light switch stilo 53 | chico85 | Lets Talk FIAT | 1 | 20-03-2008 13:18 |
