im Axle Specialists
Old 01-12-2009   #1
Heater Mists up Windows?
ok, it is now winter=cold so turning the heater on would be a thought, however if i turn mine on it just mists all my windows up, and as its getting cold outside i have to resort to turning the cold air on to demist the windows= very cold. after doing a bit of searching on here i have found that this may be the heater matrix, so just wondering how difficult is this to repair/swap(im not to good with cars) or anyone got any idea how much id be looking at paying if i took it to a garage?
the heater also smells quite a bit when i turn it on, if that helps at all.
andy20 is offline Reply With Quote Quote
Old 01-12-2009   #2
Geek of the Week
smokeyjoe03's Avatar
Trader Rating: 1
smokeyjoe03 has donated!
Aniki Pingpong Champion, Rat Zapper Champion, TIE Fighter Shooter Champion
Re: Heater Mists up Windows?
More than likely it will be blocked drainage pipes, blowing condensed water into the cabin.
Search the forum for Drainage Pipes.
smokeyjoe03 is offline Reply With Quote Quote
Old 02-12-2009   #3
you could pick up a heater matrix for around 45-50 new and around 15-25 used. you would probably pay around 1 hour labour tops. try getting quote including parts if you don't know what to get. but if you know what to get then shop around for good deals.
i know this sounds stupid but i'm guessing you have the blower settings right? i always find closing the centre vents makes the blower more powerful against the front windscreen during winter, clearing the screen quicker.
also is there any heat coming out when you set the heater to hot or is it cool or not very hot at all, is there a smell of fumes? or any funny smells infact?
Punto MK2 sporting 6speed
mahol is offline Reply With Quote Quote
Old 02-12-2009   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Is your coolant level OK?
Is the heater control on recriculation rather than fresh air?
If the coolant level is staying level,then drain tubes would be the first call?
SPD
Old 04-12-2009   #5
well thanks for the replys guys, im gonna try cleaning out the drainage pipes this weekend to see if that does the trick. and yes when i turn the heater on it does smell funny, yes it is blowing out hot air, yes i have all the settings right as in i am not recycling the air, and yes im pretty sure the coolant level is fine, well it was last time i checked and im pretty sure the heaters been doing this since i got it.
Old 04-12-2009   #6
Have you got air-con?
Its pretty common if you have air con for this to happen when the air-con is off.
Can also get the bad smell from the air con.
Will defrost best with heating on full hot and aircon turned on together. full blower
When you turm off aircon probably mist up again but less bad when the engine is fully upto temp.
geezbeez is offline Reply With Quote Quote
Old 06-12-2009   #7
The funny smell suggests you have a coolant leak in the heater matrix.
DaveMcT is online now Reply With Quote Quote
Old 07-12-2009   #8
well i tried to check my drainage pipes this weekend, however im not sure if i done it right. i opened up the bonnet and pourned some water down the windscreen and it all seemed to drain out fine, and i could see all the water coming out some sort of pipe at the bottom onto the floor. does this rule out blocked drainage pipes?
and no i dont have air con
Old 07-12-2009   #9
Pretty much yes. It sounds like the heater matrix is leaking. Change the coolant and add some RadWeld or similar. If the misting and smell persists you will need a new heater matrix.
Old 07-12-2009   #10
Autotest Special
rallycinq's Avatar
Trader Rating: 1
DO NOT ADD RADWELD.
Or even anything similar.
Can the OP confirm fluid loss, please.
SPD
Old 07-12-2009   #11
Agreed if there is no leak there is no point, check the coolant levels
But I've never had Radweld cause any problems - though of course it wont work on huge holes.
For example, My mother's VW Golf had a leaking head gasket - not the actual bores just a crack in the gasket at the back. As a temporary fix I put in some radweld and the car ran fine for another 2 years with no more coolant loss.
Old 08-12-2009   #12
Give them a clean inside with windowlene, any dust or condensation on the window will cause that extra bit of condensation. Worked for me.
DF
d3xt0r is offline Reply With Quote Quote
(T) my heater is rubbish and my windows are always wet inside! David P Marea 7 02-02-2009 18:09
(G) Ambience heater + heater fan aca Panda (Classic) 2 05-01-2009 13:37
(T) converting non elec windows to elec windows jay_mz89 Punto (Mk2/2b) 2 30-03-2008 21:37
Windows XP!! Cinnead Leisure Lounge 16 18-03-2007 16:15
(T) Windows!! Chriskelly Cinquecento / Seicento 2 05-12-2003 20:51
