Thread Tools
Old 29-11-2009   #1
Any body know rufly how much it cost to repair the handbreak?
Punto MK2 2001:
I think the cables have snapped, Theirs no tension on the handbreak at all.
How much does it cost to repair at a garage?
Thanks Jake.
Jakeyboy09 is offline Reply With Quote Quote
Old 29-11-2009   #2
Re: Any body know rufly how much it cost to repair the handbreak?
Get all 4 brakes serviced and fit a new handbrake cable. If its got rear drums fit new hand brake levers on the drums. They tend to distort with age so folks overstrain the handbrake cable.
Avoid Kwikfit etc and you should spend no more than 2 or three hours labour.
DaveMcT is offline Reply With Quote Quote
Old 29-11-2009   #3
I like to be different!
bredsticz's Avatar
Trader Rating: 1
bredsticz has donated!
Check the cables themselves first, can get easy access to them from the tray just behind the handbrake, take it off and there they are!
bredsticz is offline Reply With Quote Quote
Old 29-11-2009   #4
cheers mate will have a look now
Old 29-11-2009   #5
MikeSalt has donated!
It's a DIY job, no need to go anywhere near a garage. Check that it is one of the cables by removing the cover as described, and then check back and we'll talk you through it (jack and axle stands or ramps required).
EDIT: Just spotted it's a mk2, should be similarly easy but I'm not an expert on them.
MikeSalt is offline Reply With Quote Quote
Old 29-11-2009   #6
Cheers for the help,
Will check tommorow after work to see if a cable has snapped will it be obvious? e.g. could i spot it when i look under the hand break?
Also is their 4 diffrent cables for each tyre? or just 1 that operates them all?
And could it be anything else other than cables?
Had this car just over 1months so far:
BOTH windscreen wipers broke (FIXED)
BOTH Headlights broke (FIXED)
And now the handbrake has broke
LOL not a good start.
Cheers for the help so far.
Old 29-11-2009   #7
Quote Originally Posted by Jakeyboy09 View Post
Well done on the wipers but please get the brakes done professionally. Its not expensive and with your level of experience (see bold) its really not worth the risk.
Old 29-11-2009   #8
Well done on the wipers etc, but please get the brakes done professionally. Its not expensive and with your level of experience (see bold) its really not worth the risk.
Old 30-11-2009   #9
tim1989 has donated!
new handbrake cable fitted is around 150
1.4 16v sporting mk2b with 121.5bhp and 126 torque RIP!
owns 400BHP mitsubishi evo 8
tim1989 is offline Reply With Quote Quote
Old 30-11-2009   #10
150 is cheap if it avoids a crash; though I guess the brakes would be extra to that. If its got rear drums also get new levers fitted at the brake end as they tend to get sprained.
Old 30-11-2009   #11
bredsticz's Avatar
Trader Rating: 1
So long as the brakes are tested and working fine after a DIY job it should be fine though. 1st job I ever did on a car was on brakes.
Its 2 cables BTW running from the handbrake toward the back of the car, if one has snapped there will be no tension in it. May just need adjusting if the pads have been worn alot since it was last adjusted, may need new pads. Or cable could have just stretched. Check the pads and cables anyway and report back
Old 30-11-2009   #12
Captain Mike has donated!
rufly
Captain Mike is offline Reply With Quote Quote
Old 30-11-2009   #13
Quote Originally Posted by bredsticz View Post
Come on Im not trying to dis the OP, but he is clearly very inexperienced at any sort of car maintenance. How is he supposed to test his brakes without killing himself or worse killing someone else (like me)?
He should not touch the brakes until he at least knows how many wheels the hand brake works upon and quite probably the difference between a screwdriver and a spanner.
Jake,
Get a pro on the brakes (not KwikFit etc) and we will help you with the basics. Get a Haynes manual and some proper tools then start with servicing the engine. Then you'll appreciate how complex things can be especially if you have not done this stuff before.
Old 30-11-2009   #14
bredsticz's Avatar
Trader Rating: 1
Fair enough i get your point. Although i always tested my brakes while it was still on axle stands or jacked up. If you can't turn the wheel yourself with abit of effort with the brakes appiled then ok, but if you can turn it then obviously don't drive it, somethings wrong! :P
Old 01-12-2009   #15
Hi Bred, that's (sort of) OK if you know how many wheels the hand brake works on.
Sometimes you just "know" when something's not a good idea. This post made my hair stand on end.
Thread Tools
MOT Failure, any idea of repair cost? Mart_Sei Non-FIAT 8 28-08-2009 03:41
(T) Brava Head Gasket repair cost JuliaT Bravo / Brava 7 09-04-2008 14:42
(G) Had a Crash - Estimate of cost of repair hailesy Punto (Mk2/2b) 10 24-03-2008 22:22
Cost To fit a Body Kit Trancendental Leisure Lounge 15 09-08-2006 21:03
