Technical Mk.1 rear hubs
wavestar
the manual says that if the rear hubs are removed / dismantled the bearings , nuts etc. have to be replaced.
is this really necessary if they are ok ? I just want to replace the trailing arms
how do you edit posts ?
anyway what I should have said was it it necessary to renew the bearings and nut everytime the rear hub is taken off ? as per workshop manual.
