D diggerman New member Joined Feb 28, 2009 Messages 46 Points 16 Nov 24, 2009 #1 help when i put my heater on in my 2001 punto in stationary it smells of exhaust fumes any one help me many thanks folks
OP OP D diggerman New member Joined Feb 28, 2009 Messages 46 Points 16 Nov 24, 2009 #2 anyone cough splutter
S sixpotman Patron member Joined Dec 19, 2008 Messages 862 Points 143 Location Stoke-on-Trent Nov 24, 2009 #3 Get your exhaust and manifold checked for leaks properly. Check the end extends out beyond the back of the car. John
N nickdd New member Joined Nov 24, 2009 Messages 3 Points 2 Nov 24, 2009 #4 Hi, Are you sure it's exhaust? I recently had fumes in the car in the same way as you describe and it was a broken breather pipe to the right of the airbox. Just a thought.
D DaveMcT Distinguished member Written a guide Joined Sep 14, 2009 Messages 19,492 Points 3,294 Nov 25, 2009 #5 It could also be a coolant leak. But make sure it not the exhaust before assuming its something less harmful. Last edited: Nov 25, 2009
OP OP D diggerman New member Joined Feb 28, 2009 Messages 46 Points 16 Nov 25, 2009 #6 whats the best way to check manifold exhauast quite new where is the breather pipe sorry to sound thick but cars mechanics are a struggle to me
D DaveMcT Distinguished member Written a guide Joined Sep 14, 2009 Messages 19,492 Points 3,294 Nov 26, 2009 #7 1 - Keep an eye on the coolant level if its dropping you have the culprit 2 - Breather pipe comes off the engine block to the throttle body. Do some searches on here and you'll find lots of stuff. 3 - If exhaust is new take it back and get the pro to check it. They will do this free and if it is leaking they are the best folks to fix it.
OP OP D diggerman New member Joined Feb 28, 2009 Messages 46 Points 16 Nov 26, 2009 #8 thanks guys will do
