Jeez guys, all I did was replace a flat battery (new battery cost £50) and now I need a £65 diagnostic check???.........
can i just ask, was the management light there before the battery was changed don't know if you already said.
and did you have the old battery checked at a garage to make sure it was dead.
because im thinking if not, it may not have been the battery it could have been the spark plugs, HT leads or coil pack which would also cause problems starting up your car but would at the same time explain why the engine management light is on. because when i think about it why would the engine management light be on for a fault concerning a battery surely you would get the battery symbol???, doesn't make sense, so that's why im thinking ignition.
get where im going here, don't know if it make sense but hey
Also in my book it says if engine management light is flashing;
its a warning that the catalyser can be damaged. (
iirc this is usually as a result to the fuel not being burnt off fully before entering the exhaust system - again possible due to ignition system spark plugs, leads, coil pack)
if it solid light;
Fuel or ignition system failure.
but honestly don't part with any cash just yet, it may just be that you need to wait a week or two starting and turning off the car will sort it. if it was any of these problems ive mentioned your would notice it in your driving listen to the engine, is it using more fuel, is there a drop in performance etc.
SO DONT PANIC JUST YET
