Technical loud noise braking on a hill
NpP
My car sometimes makes quite a loud grinding noise when im braking on a hill and have my clutch down, sounds abit like a jet plane, doesnt happen all the time and there is no other noises when braking etc other than that.
any one have any idea whats up?
thankyouu :)
thankyouu :)
Take off the front wheels and see that you have at least a consistent and even 2mm of brake pad lining on your pads, if all OK check the rears. Are the discs flat or scored with a lip at the edge? If so it might make sense to replace the discs & pads, while you are at it change the brake fluid... brakes are essential safety items not just for you but other road users (y)
Why are you braking on a hill with the clutch down?
Dangerous
SPD
As im stopping so the car doesn't stall..
not coasting down it
and Ffoxy: thank you will do that!
So are you saying it only happens just as your coming to a halt and are putting the clutch in, but not at any other braking time?
SPD
yes :) the noise sounds like its coming from the back of the car too , not in the front.
thanks
Need to rule out the clutch release bearing.
With the engine running, listen to the clutch area when someone presses the pedal down. If there is a noise when the lever moves its the clutch bearing.
But regardless of that, you need to check that all 4 brakes are OK.
Yup, that was my thinking exactly.
Although further thought would euggest that the as this happen only going down a hill, the load valve changes the action of the rear brakes, so a brake service in order.
SPD
