im Axle Specialists
Old 04-11-2009   #1
Passenger Side Wiper
Yesterday my passenger side wiper stopped working, upon lifting the bonet it become noticeable straight away what the problem was. It seems that the link in the arm has come apart, I attached images of the problem, could someone please tell me what the best way to fix this is? hopefully it wont be too expensive.
Thanks in advance.
Peter.
ID:	70500   Click image for larger version
ID:	70502   Click image for larger version
pcharles is offline Reply With Quote Quote
Old 04-11-2009   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Passenger Side Wiper
You might be lucky and be able to 'pop' it back on. Looking at the rust around there would suggest a shortage of lube.
This problem is usually an effect of the spindle seizing up. Clean and lubricate the spindle.
SPD
Old 04-11-2009   #3
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
I've seen all sorts of temporary bodges for this from cable ties to insulation tape... a new linkage is the proper solution obviously, one from a scrappies could fall to bits anytime really.
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 04-11-2009   #4
Thanks for the quick response, I had a go at pushing it back on but assumed that something was missing or broken. From what your saying should it just be a matter of applying a bit of force to push it back on? Then a bit of grease or WD40.
Thanks.
Peter
Old 04-11-2009   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by pcharles View Post
Thanks.
Peter
Yup, bit of force, but do sort the spindle first, or it will happen again.
Each time it happens the ball joint gets slacker.
SPD
Old 04-11-2009   #6
Ok Thanks, I will try this and let you know how I get on.
Old 04-11-2009   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Just take it out, strip it, abrade any rust on the spindle and in its holder, dod of grease and back together.
SPD
Old 05-11-2009   #8
I am going to try and fix this at the weekend, if I have no luck I am probably going to buy the new the replacement push rod set from wipex. Does anyone know how easy this is to fit? Is it easy to remove the existing ball joints?
Thanks again.
Your help is very much appreciated.
Peter
Old 06-11-2009   #9
i had exactly the same problem, went for new linkage ended up costing me 190 quid fitted. just hope if won't go wrong again. i'd get it sorted, i've had 2 many experiences of trying 2 fix in the rain when it pops out again.
gajamaflake is offline Reply With Quote Quote
Old 06-11-2009   #10
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Thanks again.
Peter
I find long nose pliers good for getting balljoints off, put the points inbeteween the arms and a slight 'levering' will allow them to pop off. Service the spindles while in there.
SPD
Old 08-11-2009   #11
Quote Originally Posted by rallycinq View Post
SPD
Pop them off every winter, clean up the gunk and re-grease and they should last for ever. Ditto the ball joints on the gearbox shift cables.
DaveMcT is offline Reply With Quote Quote
(G) any body got seat belt anchor for driver side and passenger side left please help me kimtom Cinquecento / Seicento 2 23-02-2008 14:47
(T) Passenger side windscreen wiper broken? ccyc87 Punto (Mk2/2b) 2 25-08-2007 01:24
(G) Punto passenger wiper 1mayfield Punto (Mk2/2b) 2 29-04-2007 20:32
(T) Passenger Wiper Linkage problem TidyBoy Punto (Mk2/2b) 5 26-06-2006 20:07
need new rear passenger side door and front passaenger side wing rocket man Bodyshop 1 08-01-2006 12:20
