chaos123007
- Oct 9, 2009
- 32
- 12
is there a way of checking the water pump operation?, ave changed the thermostat as my car was blowing cold air and now it heats up no problem.
reason for changing thermostat was a slight milky residue in my oil cap, apart from it not working either lol and understand that it is the most common failing of a head gasket.
car did give off a skrech when i had replaced the thermostat, i assume this was the water pump getting rid of the air in the system?
car heats up fine and sits and 1/4 most of the time and doesnt go above half.
what causes a thermostat to fail ?.
i am doing alot of work to this car, and im about to change the coils and ht leads as i have that annoying power loss to.
thanx for reading
thanx for reading
