Old 14-12-2004   #1
changing gear knob
I have a mk1 punto (pushes down for reverse gear) and want to change the gaiter and gear knob.
I have read through several posts on here but some say you just pull it, some say it needs cutting. Which is the best plan of action?
Do I need a special gear knob or is that just for the lift up gears on mk2?
thanks
madmish is offline Reply With Quote Quote
Old 14-12-2004   #2
wolfracepunto has donated!
Re: changing gear knob
On the mk2, the knob just pulls off- dont need to twist it or anything. Probably the same on the mk1.
If you push down to get reverse, it usually means the whole gearstick moves, not just the gearknob so a normal gearknob would most likely be needed.
BMW 123d M Sport Auto
'10 Focus ST-3 Gone
Hornet 600 K8 Sold
wolfracepunto is offline Reply With Quote Quote
Old 14-12-2004   #3
sammiboo has donated!
you do have to cut it.
the standard gear knob is moulded you can cut it off using a hack saw make a cross cut along the middle and across then should come off easy enough.
MK1 puntos arent lift up reverse WR
sammiboo is offline Reply With Quote Quote
Old 14-12-2004   #4
I know theyre not lift up reverse, his post says so. I was saying he probably doesnt need a special gearknob after he's taken the old one off. But I didnt know you had to cut the old knob off
'10 Focus ST-3 Gone
Hornet 600 K8 Sold
Old 15-12-2004   #5
dave's Avatar
Trader Rating: 10
dave has donated!
some times you have to cut the knobs off, but if you are strong though an pull very hard it will come off but watch head on inside of roof
THIS IS WHY TORIES CANT CLAIM HINDSIGHT! https://www.youtube.com/watch?v=bQDPQ8bz7cU
Old 27-12-2004   #6
Quote Originally Posted by dave
This cuttings of knobs sounds a bit sore, but anyhoo I'm considering buying the gear knob in the pic below, anyone have any idea if there are any cables or anything for the lights? Any more info would be appreciated.
CKYDave is offline Reply With Quote Quote
Old 27-12-2004   #7
I belive there's a cable from the gearknob that you need to hook up to a 12v supply, to run the led's.. shouldnt be too hard to hook up - just hiding the wire :P
I'm not certain as I've never seen nor used one but they need a supply from somwhere
space is offline Reply With Quote Quote
Old 27-12-2004   #8
Banned
the twist off top reveals 4 small batteries a bit bigger then the ones you put in your watch
oatcake1 is offline Reply With Quote Quote
Old 27-12-2004   #9
Quote Originally Posted by oatcake1
Excellent, that's what I was hoping for!
(S) Cinq gear knob - New way around the problem Cinq_Sport_BiG_DaVE Cinquecento / Seicento 32 06-09-2005 16:22
(G) gear knob d miller Panda (Classic) 1 02-04-2004 04:59
(S) Gear Knob Replacement polecat Marea 0 15-02-2004 22:09
(T) changing gear knob? dprizmic Punto (Mk2/2b) 9 07-02-2004 02:22
(S) Gear Knob Pete600 Cinquecento / Seicento 10 08-05-2003 05:33
