General Air locks in coolent
kevincox1987
how do u bleed?with car runnin?then open the bleed screw our not?our is there another way can i buy something like a fluid i can put in with water 2 get rid of air locks? thanks
https://www.fiatforum.com/punto-guides/43906-how-bleed-punto-cooling-system.html
I fill the tank all the way up then bleed rad first. Fill up to top of tank again(above max) and bleed the matrix (you may need to refill the tank up to the top again), then use the rad bleed to lower the water in the tank to normal level. Run the engine for 10 mins, leave to cool and check level again.
If you are needing to bleed every so often then you may have a problem.
