fzr400exup
- Dec 9, 2004
- 2
- 1
Hi Guys,
new to this site, and was wondering if you can help, I have a 1.1 (95)twinspark, Im fairly good in general with cars, but there are always giggle pins, fu fu valves and flux capacitors that I cant find !
any way long and short of it, overheated head gasket gone, got it skimmed, refitted all timed up ok, compression fine, but only runs on two cylinders, swapped over the coil packs the problem stays with same two cylinders, by the way, one coil pack is running the two cylinders, any ideas please, ignition amp? by the way where is it?
Jon
Jon
