- Jan 17, 2009
- 7
- 4
Hi All, My Mates Fiat Punto MK2b Has just come up with loads of ECU error codes and disabled his Airbag. TYhe engine when idoling the revs jump from 1000 to about 700 and back up about once a second, sometimes it cuts itself off. He took it to a garage and they told him that the ECU was finished and giving off ALOT of error codes.
My Main Question is, can i get an ECU from the Scrap yard and fit it into the Car and it work?, Do you need special Equiptement to fit the ECU (AKA Fiat ECU Reset). On His Car the ECU, Airbag, Blown Bulb Light warning and and Power Steering light, Are all lit up on the dash.
If i try this ECU to see if it fixed the problem, could it disable or lock up any of the cars Security Devices (Doesnt have an Alarm)
Also Can a Fiat Punto MK2 Active Sport ECU be fitted onto a Flain Fiat Punto MK2b?
Kindest Regards
Jamie Cruickshank
Kindest Regards
Jamie Cruickshank
