im Axle Specialists
Old 01-09-2009   #1
upgradeing breaks !
hey im looking to upgrade my brakes on a mk2 1999 punto as the current ones are abit pants. is there any recomendations? i was thinkin bout takin breaks of a bigger moddel of fiat like a stilo maby? would this actualy improve them? i am on a small budget tho so it needs to be as cheep as posible
cheers guys
hefty69 is offline Reply With Quote Quote
Old 02-09-2009   #2
sdb-punto's evil twin
1383matt's Avatar
1383matt has donated!
Re: upgradeing breaks !
look at these links.
this one says what calipers you can use.
https://www.fiatforum.com/punto-faqs...nto-front.html
and this one is my thread from when i uprated my brakes, definately worth the money brilliant upgrade. from the top of my head i paid £20 for calipers and £65 for pads discs brake lines and some dot 4 fluid.
https://www.fiatforum.com/punto/199956-new-brakes.html
1383matt is offline Reply With Quote Quote
Old 02-09-2009   #3
MikeSalt has donated!
hefty, what model of mkII Punto have you got? You have to be a bit careful not to upgrade the front brakes too much from stock since the front-rear balance will be upset. Therefore, if you have 240mm x 11mm solid discs, and drums at the rear, I would not recommend going much further than a Punto GT front brake setup (257mm x 20mm vented) with decent pads like EBC Green Stuff or Ferodo DS.
MikeSalt is offline Reply With Quote Quote
Old 02-09-2009   #4
its an x reg 1.2. yehh thanks alot for that guys
Old 03-09-2009   #5
Quote Originally Posted by hefty69 View Post
In that case, unless it has ABS it will be 240mm x 11mm solid discs. And upgrade to mk1 GT brakes (257mm x 20mm vented) with a set of performance pads should see you right.
(G) New breaks Danny westall Grande Punto 10 06-05-2009 14:01
Breaks PobAloB Bodyshop 1 16-12-2008 20:45
(T) breaks stumpy102 Punto (Mk2/2b) 8 26-04-2007 11:15
(G) can u help me with my breaks? moooz Punto (Mk2/2b) 4 11-01-2005 13:28
(G) breaks?? Donkey Cinquecento / Seicento 1 23-08-2004 00:24
