i wanna lower my car a bit more but dunno how low it is already as i brought it like this.
would 50mm be alot lower then this?
also would these fit http://www.spax-suspension.co.uk/p1326132.htm
and what shocks should i get?
thanks
Looks like 35mm drop to me.
You got a better side on photo?
Dampers wise Bilstein OE spec are very good for road use IME
how are u finding them plus u got a photo to show how low it isI have the PI 50mm shocks and springs on mine
ive not used any others so i cant compare to others, richie is the best one to ask
£400 will get you the setup I listed.
I think it came in around £360.
Edit : £356.10 from Europerformance
whats the ride like on coilovers, apparently realy bumpy?whats your budget?
coilovers will get you really low, and offer decent handling (not when completely decked). A decent set of FK's will set you back about £500ish
or you can get a decent damper and spring set up, the cost, dependant upon which you go for.
how much did they set u back?Look if u have money definately go with coilovers... If u buy better ones u will have the ability to set not only height but the hardness of them...
I have coilovers on my punto and i can say only the best for it.
