Some may come across my punto needed a heart-transplant a few weeks ago. Finally I got it back the week before last after an engine replacement.
But the overheating problem is still haunting. The overheating indicator comes up very easily from dim to
bright just within a few miles. So I hardly dare to drive it too much fearing this engne cooked again.
Here is some observations and facts relating to the problem:
Before the old engine cooked, I had the radiator fan swtich changed due to a similar overheating
problem (I suspect the headgast has possibly been seriously damaged then) as diagonized by a local garage. The garage told the fan kicked in but at a higher temperature than it should. A few weeks later, the engine gone.
The garage that did engine swap failed to come up with any idea. They claimed only very dim light was
observed when they tested it. They changed the thermostat, anti-freeze, oil filter, radiator cap etc. They warned of poor radiator condition though.
It blows hot air from air conditions.
Tried to bleed airblock in coolant system. Found two bleed valves totally and a small amount of air seen out.
The fan does kick in after idle for a while. But the overheating indicator remains bright.
No milky sign in oil.
One interesting thing is that, if i leave the car idle for one or two minutes before driving away, the light comes on much slower and keeps dim for long time (actually I havn't seen it become fully bright possibly because didn't drive for long distance). The light comes on within 5 mins and turn bright if I drive away right after I turn on the engine.
I am wondering how to test whether it is just a faulty indicator (i.e. no real overheating problem).
Thinking of testing the swtich and blushing the radiator this weekend before this engine is cooked again.
Any suggestions guys? Thanks in advance.
