Old 30-11-2004   #1
Nicko12345@gmail.com
NICKO_12345's Avatar
Trader Rating: 1
NICKO_12345 has donated!
how hard is it to fit a induction kit???
on a mark 2 punto??? 1.2 8v???? 3 door?? 2000 model????
NICKO_12345 is offline Reply With Quote Quote
Old 30-11-2004   #2
Re: how hard is it to fit a induction kit???
Took me about 20-30 mins and i was clueless just before i started. Is pretty simple just follow the intructions the kit comes with and make sure you dont take the fuel line out like i did (DOH!)
Id recomend gettin someone to help you like a mate just as its much easier with two people.
SlinK is offline Reply With Quote Quote
Old 30-11-2004   #3
Trader Rating: 1
you fit a k&n one???
is it right you need another hose going to it to get it work proper or something??
Old 30-11-2004   #4
Ye it was a K&N 57i one for my MK1 1.1 Punto. Im not sure what u mean by another hose to get it working but if you mean a cold air feed then it should come with one. I just bought another 2 for it and managed to find a good place for one but struggling to place the other one in.
Old 30-11-2004   #5
Trader Rating: 1
so all in all a simple job, i got a mark 2 1.2 8v will i notice any diffrence in performance???? www.fastfiat.com cheapest place so far @74 quid??? anyone seen lower???
Old 30-11-2004   #6
You will notice a performance difference. I have a K&N on a MK1 1.2 Sporting. THe difference I found was smoother and faster acceleration, BUT you do need the cold air feed. That was the hardest part of the installation for me mainly because it is bloddy fiddley trying to remove the blocking plate behind the front grill. IT is all attached now, but I would recommend fine mesh across the grill to stop large objects ie leaves flies, travelling up to the filter.
The fitting instructions are well written clear and include excellent pictures of the car you have bought it for.
Oh yeah, and the car will sound great.
And 74 is good...mine cost 89.
PS...Opinion is that K&N last longer than Pipercross
Niz
Black MK1 Punto Sporting
Nizanh is offline Reply With Quote Quote
Old 30-11-2004   #7
wolfracepunto has donated!
Quote Originally Posted by NICKO_12345
On the 8v engine its really easy to fit, toom me about 20mins tops first time (now takes about 5mins when im taking car to dealers ) If you disconnect your battery after fitting the kit, for an hour or so, then reconnect it and drive like a tosser (with your foot to the floor) The ECU will teach itself that more air is coming into the engine and adjust the mixture....I think!
BMW 123d M Sport Auto
'10 Focus ST-3 Gone
Hornet 600 K8 Sold
wolfracepunto is offline Reply With Quote Quote
Old 01-12-2004   #8
Professional Know-It-All
MR.COATES's Avatar
MR.COATES has donated!
Fitting to a MK2 1.2 8v is a piece of p*ss.
If you're an idiot it shold take you 40 minutes at the most.
If not, anywhere between 15 and 30.
But I honestly wouldn't bother with the K&N. Now that I've got the BMC CDA (sure, it's twice the price), the K&N is shameful in comparison.
Yes, if you're ONLY after a noise, go for it. But that's a big way to blow 75. I'd suggest saving for the BMC and then looking onwards towards a better exhaust at a later date.
The K&N on the 8v is a poor design - it simply draws too much heat from the engine bay (regardless of how many hoses you add). The BMC is a closed filter and draws the air directly from the front so no warm air is brought in.
The main problem with the K&N on the 8v is that it's right by the engine, it has a 360 degree exposed element and the hoses only point at the front (or side). This means you've ALWAYS got part of the filter being exposed to warm air.
At first, you BET the K&N will put a smile on your face but over time I guarantee this will fade and if you compare it to the BMC you will wish you'd spent the extra (if you can afford it).
Just my 10p's worth but I've been through this myself and have in the end luckily sold my K&N at only a bit of a loss.
If you want to know more, just ask (and no I'm not on commission - just want you guys & gals to get the best).
__________________________________
Yellow Punto? A bit girly isn't it?
http://img9.exs.cx/img9/8633/fogs.gif
MR.COATES is offline Reply With Quote Quote
Old 01-12-2004   #9
Trader Rating: 1
mr coates, im very interested in what you have to say, it aint just a sound for me, can you show me a like or anything where i can read up on the system you on about, maybe a site where i can buy online?????
many thanks nick
Old 01-12-2004   #10
MR.COATES's Avatar
Consider it done.....
http://www.motorsportworld.co.uk/det...-72&PID=326986
The picture is not how I have mine fitted, I'll get a pic posted at some point.
http://www.bmcairfilters.com/infoCDA.asp
Old 01-12-2004   #11
MR.COATES's Avatar
And point to note, the BMC still makes a nice sound, just more refined than the booming K&N (which actually annoyed me after a while!!)
Old 01-12-2004   #12
Trader Rating: 1
looks good, do you need a cold air feed or anything for it???
because having the titan kit on my car there is alot of mesh at the front for things like that??
cheers for the links btw
Old 01-12-2004   #13
MR.COATES's Avatar
The cold feed plugs DIRECTLY onto the carbon box so it works more like a hoover - actively sucking the air to the filter.
Old 01-12-2004   #14
Trader Rating: 1
oh right, cool, seen the light now, k&n is the boy racer thing, the people in the no go for this, am i right or what????
Old 01-12-2004   #15
MR.COATES's Avatar
In my opinion yes.
I've had both, paid for them full price and I can only say that if you want real performance gains and a noticable sound improvement, the BMC CDA is without question the one to get.
If you want to be heard but aren't bothered by any major difference in performance, save 75 and go for the K&N.
Top tip though, send a message to Andy (nwmlargee) and get him to quote you on a price for the BMC. May be about 15 or so less than the site I linked to.
Tell him MR.COATES sent you.
(T) Green Induction Kit gaz.d Cinquecento / Seicento 2 20-05-2004 00:55
(T) GSR F1i Induction Kit surfin_fella Cinquecento / Seicento 8 27-02-2004 19:51
(G) Induction kit stubbsieyourule Cinquecento / Seicento 5 07-04-2003 02:22
(G) PandaMan - Induction Kit gaz.d Panda (Classic) 2 10-12-2002 23:11
