title speaks for itself. gotta push hard, sometimes shift twice to get into a gear, especially 1st. could it be somethin basic like changin the gear oil?
Cheers mate! :slayer: I was gonna change it even if it wasn't the reason for this problemGearbox Oil most likely
It's the same with the engine offIf you can select the gears easier with the engine off I would say its the clutch too.
What did you spray? the linkages? or...?When i hadnt used mine for a while it was sticking, i just sprayed it with lots of lubricant and it is much better now.
My mk1 1.2 16v is having a similar issue, mainly from 1st-2nd and sometimes 2nd-3rd. Sometimes grinds going into reverse. Clutch bite is really low, could it just need adjusting or a new clutch?
