***UPDATE***
Hi, right, finally getting somewhere now
New dash loom arrived today and has been installed in the dash.
carpet is back in, and all the front loom is in place.
new section of loom running from the fusebox to the radiator cooling fan under the bonnet is in place.. everything under the bonnet is also properly in place now, and connected up minus indicators and the front fogs.
replacement battery box/container is in place..but found out dealer had provided the wrong battery.. so a replacement is arriving tomorrow
but had to order further sections of loom
upon installing the front loom I wondered why there was no heater loom.. but instead a multiplug, and realised that the multiplug had been cut out.. and in its place a load of block connectors.. which initially I thought was just a repair job.. but now I realise it was actually done to bypass the multiplugs.
so then I ordered what I thought was the loom for it.. but today it arrived and was just a bunch of bulb holders with a multiplug for the lighting behind the heater controls..which I thought was strange.. because on the existing one the bulb holders were part of the same loom as the heater box..and upon closer inspection.. I found that yet again multiplugs had been cut off the loom.. and the multiplug on the bulb holders loom had been cut off.. and the wires directly soldered onto the loom... then taped up afterwards in such a way that it looked like part of the loom.
So I ended up ordering a further section of loom for the actual heater box.
Have to say though.. I really dont know how they come up with their prices.... heres a rough idea,
Front loom - absolutely huge.. comes with the base for the fuse box.. wires that run behind the slam panel, to abs unit.. inside the car passenger side down into the footwell, and drivers side to the fusebox and switches under the steering column, wires to the ABS sensors at the back of the car, sensor under the drivers seat, and electronic unit under the heaterbox in the centre console.
£180
Dash loom - Relatively small in comparison, and just runs behind the dash going to the switches at the top eg hazzards... passenger airbag disable switch passenger and driver airbag, audio unit, clocks, cigarette lighter, etc
£299.20
Ironic thing as well.. first loom they supplied which was incorrect - no audio connections for 1 thing.. was actually half that price @£150 roughly.. so for a few extra wires and connectors the price doubles.
then you get an even smaller loom still.. probably smallest major loom on the car.. the engine loom (which I didnt order btw, as there seems to be nothing wrong with the existing loom.)
£300
but, I did have to order a really small section of loom.. which just runs from the fusebox, and has 2 connectors on the end connecting to the cooling fan... couldnt of been more than 2 ft long.
£31.14 - If I had the connectors and knew how it was wired up and had the stuff available I could of probably made it for under a tenner.
and the heater loom...
£38.93
and the bulb holders...
£15.49.
Again.. for whats in it.. maybe £5 worth of stuff.
Hopefully thats everything, Engine was running fine, so the engine loom should be ok.. dont really like the cost of it lol at £300.. and the rear loom just connects to the front door doing things like electric windows, electric mirrors, fuel pump, sender, and rear lighting. which was all working fine anyway.. and doesnt appear to of been messed about too much, as it is in a reasonably good condition.
There is a bit in the drivers footwell which needs tidying up, because it was chopped about for the alarm but seeming as its only a minor loom in comparison to the front and dash loom im hoping I can get away with tidying those wires up with some solder and shrink wrap, dont want to replace another £300 loom unless its necessary, but least if it does need doing the dash doesnt need to come out just seats and carpet so its an easy one to do.
Good job the car was cheap to begin with! Just hope theres no more nasty surprises..still need to wait and see what hapens with the body computer and the abs unit...will know this week if those are scrap or not.
Least its now slowly coming back into a safe and good condition. But I didnt really want to start chopping up a brand new loom.. so all the extra bits of loom couldnt be avoided. Let just hope it all works lol.
