Thread Tools
Old 21-07-2009   #1
Ireland
Torque settings - Crank Pulley Bolts, Cam Bearings ?
Evening all, I've already done a headgasket change on my Mk1 Punto and the car is a runner but just wanted to check if anyone knows what the torque setting is for the 3 bolts that hold on the crank pulley ? In the Haynes it lists everything but that or am I looking for the wrong thing ??
While I'm on the subject of torque settings I'm gonna be doing the shims soon, there is 3 cam shaft bearings which ones are the M8 and M8 x 1.25 screws as the first is 10nm and the other is 20nm.
One of my mates said it doesn't a whole lot just don't over do it but once I get something in my head I have to find out for sure which is which.
Many thanks lads
DIYer is offline Reply With Quote Quote
Old 24-07-2009   #2
sdb-punto's evil twin
1383matt's Avatar
1383matt has donated!
Re: Torque settings - Crank Pulley Bolts, Cam Bearings ?
the crank pulley bolts just have to be tight, and the cam cover is just off finger tight so 10nm will be fine.
1383matt is offline Reply With Quote Quote
Old 24-07-2009   #3
Ireland
Thats for that 1383matt had a feeling the cam pulley was just tight if it was listed but better safe than sorry.
P { MARGIN-TOP: 0px; MARGIN-BOTTOM: 0px } BODY { SCROLLBAR-HIGHLIGHT-COLOR: #cecfce; SCROLLBAR-ARROW-COLOR: #3f52b8; SCROLLBAR-TRACK-COLOR: #fffbff; SCROLLBAR-DARKSHADOW-COLOR: #fafafa; SCROLLBAR-BASE-COLOR: #f7f7f7 } The camshaft bearings was the other ones, in the Haynes its list :
M8 : 10nm
M8 x 1.25 : 20nm
How do I know which Camshaft bearings bolts are which ?
Whats the different between and M8 bolt and a M8 X 1.25 ?
Thanks again
Old 24-07-2009   #4
1383matt's Avatar
m10's are bigger. the six cam holder bolts need to be 20nm.
Thread Tools
(T) cam holder torque settings gazzaman2k Cinquecento / Seicento 2 24-06-2009 09:58
(T) cam shaft torque settings wantedman Punto (Mk2/2b) 1 14-07-2007 15:27
(T) Torque settings for cam shaft bearing cap bolts wantedman Punto (Mk2/2b) 2 14-07-2007 14:32
(T) cam bearing caps - torque settings? arc Cinquecento / Seicento 10 23-12-2005 19:53
(G) uno fire 1100 head bolts torque settings stash Uno 1 08-02-2004 21:46
