Technical Punto acceleration problems
zapiy
Hello,
I posted a few weeks ago regarding how to do the Timing and today i managed with a friend to look at this and we noted all the timing marks lined up correctly, i also clean the sensor but this has had no effect.
I will try to explain what happens and hopefully someone can help me out. When i first start the car from cold its very sluggish and some times it backfires (only and small popping sound not a large bang). Once i get it started i allow it to heat up and try to pull away but to pull away without any kangaroo effects (holdingback/ jumping forward) i have to give it plenty revs. Also i have noticed that its more of a problem at low revs and if for example i was going a steady 40mph (i dont notice and probs here) but wanted to push towards 50mph as soon as i hit the accelerator i get some slight kangeroo effects. Does anyone have any ideas?
Well we checked the plugs and all were a sandy colour which i guess is ok, but how can i check the leads and where is the coil pack?
well sandy color is correct color for plugs.
the ht leads can be visualy checked make sure there are no cracks or splits along the length of the casing.
the coil packs are what the ht leads plug into (other end to the spark plug) i dont know how you can check these. someone else on here may no.
what car have you got by the way?
Punto 1.1 sx mate
"Hello dave"
Can i assume as the Spark plugs have a sandy colour that all the plugs are ok and that the leads are ok and the coil is ok as they all the this one job?
Cheers mate, will this prove the coil, leads and plugs work?
Any other ideas as going to scrapyard tomoz with uncle and have another look...
ok mate should i get anything from the scrappy,
ecu, carb, leads etc...
mine had a weber carb? or what i thought was a carb
my car is a 55s n reg
No sweat would never nick from someone trying to make a living..
Spi ummm that could not cause my fault then?
Had exactly the same problem as you Zapiy. My Punto was like a bumper car for the first few minutes after start up. I changed both the plugs and HT leads and no probs since. I reckon its the leads that need to be changed.
It's not a good feeling when you get in the car in the morning and wonder if the car is going to play up. Hope you get it sorted.
