Yellow gunk/oil splashing into air box via crankcase breather, wtf...
I replaced the crankcase cover gasket thinking it might of been that or the breather blocked which is no longer blocked aswell. is it piston rings need replacing? i'm replacing the main head gasket this weekend so should i replace the pistons aswell??
another symptom is a bad sounding grind noise on 1st rev before fully starting up... but it happens rarely.
-mo
-mo
