bensyellowhgt
does any one what the standard brake disc size is on front and back of a mk2 punto hgt and what pot caliper do they use.looking to upgrade brakes and calipers but dont want a big brake conversion kit
ok cool,i be off searching the internet now.thanks for your help
I've had the calipers off before to paint but, i dont have a socket big enough for the bolt on the hub. does anyone know the size?
sorry but dont know the bolt size but was wondering are the ebc disc you bought bigger then the orginals or same size
Hang on a minute, if it is just discs and pads you're replacing, you don't undo the big hub nut. You take the wheel off, and unscrew those two spikey things from the disc, and then the disc should pull right off.
If you remove the hub nut, you'll need a brand new one to refit it.
